Community
Command Central
MVP Program
Monthly Mission
Blogs
Groups
Events
Media Vault
SolarWinds Academy
Products
Observability
Application Management
IT Security
IT Service Management
System Management
Database Management
Goal Oriented AI
Content Exchange
SolarWinds Platform
Server & Application Monitor
Database Performance Analyzer
Server Configuration Monitor
Network Performance Monitor
Network Configuration Manager
SQL Sentry
Web Help Desk
Free Tools & Trials
Store
Home
Products
monitoring interface errors/collisions
daxvancamp1
I want to monitor interface errors and collisions but can't find the correct OID for this, but this is what I think will provide me with the correct output:
5 minute input rate 10000 bits/sec, 7 packets/sec
5 minute output rate 142000 bits/sec, 24 packets/sec
143297898 packets input, 34571883835 bytes, 0 no buffer
Received 2732090 broadcasts (295488 multicast)
0 runts, 0 giants, 0 throttles
0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored
0 input packets with dribble condition detected
253560814 packets output, 117274967390 bytes, 0 underruns
1341799 output errors, 542123 collisions, 0 interface resets
0 babbles, 259128 late collision, 0 deferred
0 lost carrier, 0 no carrier
0 output buffer failures, 0 output buffers swapped out
-> input errors: 1.3.6.1.2.1.2.2.1.14 ( ifinerors )
-> crc: ?
-> output errors: 1.3.6.1.2.1.2.2.1.20 ( ifouterrors )
-> collisions: 1.3.6.1.2.1.10.7.2.1.4 ( dot3statssinglecollisionframes )
-> late collisions: 1.3.6.1.2.1.10.7.2.1.8 ( dot3statslatecollisions )
BUT, these are incremented figures, I'd like to have an average per second or a way to see how many of these errors occur on a timed measurement ( like x/hour or x/day )
Find more posts tagged with
Accepted answers
All comments
edwardle
To monitor CRCs, you could try monitoring 1.3.6.1.2.1.10.7.2.1.3 (dot3StatsFCSErrors) from the ETHERLIKE MIB. More details on this MIB:
tools.cisco.com/.../BrowseOID.do
I generally find the out of the box interface monitoring is OK which just monitors transmit errors, but then again, all my interfaces are full duplex, so I'm not interested in collisions and generally any errors I see are CRC.
Remember that collisions are normal for a half duplex interface, especially if there are many other devices on the same segment. If this interace is not meant to be half duplex - check that you haven't got a duplex mismatch. It is not unusual for ports set to auto speed and duplex to negotiate incorrectly. I always force the speed and duplex on the port. The only reason I've babbled on about duplex is that it's not that common to see half duplex interfaces and collisions these days in network infrastructures, unless you've got some really old kit.
Hope this helps.
daxvancamp1
thnx for the information, but i have an additional question.
How am I able to setup this monitoring to be an incremental view on a daily basis ?
I have no clue what to use in the Mib poller properties
Rate ?
Counter ?
unit ?
timeframe ?
What's the exact explanation for these properties, it's nowwhere explained at all.
edwardle
These MIB values are counters. Leave the unit and timeframe fields blank.
Once the poller has been created, you can then add a custom poller chart to the orion web site to graph your data.
Quick Links
All Categories
Recent Posts
Activity
Unanswered
Groups
Help
Best Of
