Community
Command Central
MVP Program
Monthly Mission
Blogs
Groups
Events
Media Vault
SolarWinds Academy
Products
Goal Oriented AI
Observability
Application Management
IT Security
IT Service Management
System Management
Database Management
Content Exchange
SolarWinds Platform
Server & Application Monitor
Database Performance Analyzer
Server Configuration Monitor
Network Performance Monitor
Network Configuration Manager
SQL Sentry
Web Help Desk
Free Tools & Trials
Store
Home
Products
ONPM fails to read interface info
myexilus
For about a year, I used the Engineers's edition to monitor traffic on all Nortel BPS switches on my network. I start ro migrate over to Orion and the traffic on the interfaces are ZERO.
When displayed the interface details, it reads:
Transmit Bandwith = 0
Receive Transmit = 0
Nortel don't think it's their problem since the previous version works fine....
Any help would be appreciated...
I value your input.
Find more posts tagged with
Accepted answers
All comments
MrSNMP
The Orion NPM automatically tests the device to see if it can use the 64-bit counters for the interface traffic. In some cases, devices test positive but don't actually provide good data in these MIBs. You can right-click on the interface within the System Manager and choose "Interface Details" to see if it is using 64-bit counters for the interface. If it is, you can use a registry setting to override this and force the use of 32-bit counters.
I think that the registry setting is in \\HKEY_LOCAL_MACHINE\Software\SolarWinds.Net\SWNetPerfMon\Settings\Disable 64 bit counters set the value to "True".--HTH
myexilus
Thanks MrSNMP for replying. I did check the interface details and find out that the Counter64 support is NO. However I was able to find out what causes the problem. This is it:
When I enable an Alert and requires an E-mail to be sent to me, there is a pop-up error on the screen " Email notification server 'runtime error 6 overflow'. As long as the error is on the screen the (?)shows for any interface added for Nortel, Cisco and 3COM. Also the error shows up when I disable an interface forcing Solarwinds to send me an e-mail.
When the error is clear on the screen, then everything gets back to normal.
I am still unable to fix the problem.
I value your input.
Quick Links
All Categories
Recent Posts
Activity
Unanswered
Groups
Help
Best Of
