Is there a means to take a Universal Device Poller (value) and insert it as a column in a custom Report? I'm not seeing any such option as I click through various available fields.
Thanks in advance.
Chris, I've only been able to do this using advanced SQL queries.I can provide you an example report if you like.
-JP
It should be possible in 9.1. Report Writer schemas have been updated.
see the following post:
