Community
Command Central
MVP Program
Monthly Mission
Blogs
Groups
Events
Media Vault
SolarWinds Academy
Products
Goal Oriented AI
Observability
Application Management
IT Security
IT Service Management
System Management
Database Management
Content Exchange
SolarWinds Platform
Server & Application Monitor
Database Performance Analyzer
Server Configuration Monitor
Network Performance Monitor
Network Configuration Manager
SQL Sentry
Web Help Desk
Free Tools & Trials
Store
Home
Products
monitor IP w/o alerting
mschwarz
I have several offices that have ISDN connections that dial when the primary T1 goes down. I would like to display the ISDN connection status via pinging the interface IP so that I can graphically see that it is up when the T1 drops. But 99% of the time the ISDN connection is down and I'd rather not see the warnings on my Solar Winds map all the time. Is there a way to add a node to Orian and not have alerting on it or is there a way to reverse alert a node so that the node goes into alarm only when it is up?
Thanks for any advice, -Matt
Find more posts tagged with
Accepted answers
All comments
Network_Guru
Hi Matt,
This question has been asked before, but it seems like there is no real solution to this one:
I did a search for "isdn" & found these posts.
www2.solarwinds.net/.../topic.asp
-=Cheers=-
NG
ceclark
It's only in Beta currently, but you could use the SNMP Trap Alert. That might solve half of your requirements. It can notify when it sees a specific trap (ie BRI channel up).
mschwarz
ok. Thank you for all your replies. It doesnt look like there is a good way to integrate this typical network layout.
But... I like the idea of creating a separate group just for my ISDN connections. When that Icon turns green then I know ISDN kicked in somewhere and I can pull up the ISDN group to check it out. I may play with putting the isdn connection on my main map and suppress the alerts w/in Solar winds.
Still waiting for SNMP V3 support... December I guess.
-Matt
Quick Links
All Categories
Recent Posts
Activity
Unanswered
Groups
Help
Best Of
