Community
Command Central
MVP Program
Monthly Mission
Blogs
Groups
Events
Media Vault
SolarWinds Academy
Products
Observability
Application Management
IT Security
IT Service Management
System Management
Database Management
Content Exchange
SolarWinds Platform
Server & Application Monitor
Database Performance Analyzer
Server Configuration Monitor
Network Performance Monitor
Network Configuration Manager
SQL Sentry
Web Help Desk
Free Tools & Trials
Store
Home
Products
Engineer's Toolset
Tracking down a device by the mac address
boe
If I only have a MAC address, is there a way to track down the IP address or resolve the name?
Find more posts tagged with
Accepted answers
All comments
Bryan
Depending on the layout of your network, you could do an ARP lookup from one of your routers.. This will give you an IP address. With the IP address, you should be able to narrow down your search to a particular segment. From there you could run the SW switch port mapper on the switches within the IP segment to find the exact port the host is plugged into. You can also do a trace route once you've resolved the MAC to IP. Hope this helps.
Bryan
Lockheed Martin
Atlas V Launch Operations
Network Engineer
boe
Thanks!
I was hoping there would be a tool in solarwinds for this.
Quick Links
All Categories
Recent Posts
Activity
Unanswered
Groups
Help
Best Of
