Community
Command Central
MVP Program
Monthly Mission
Blogs
Groups
Events
Media Vault
SolarWinds Academy
Products
Observability
Application Management
IT Security
IT Service Management
System Management
Database Management
Goal Oriented AI
Content Exchange
SolarWinds Platform
Server & Application Monitor
Database Performance Analyzer
Server Configuration Monitor
Network Performance Monitor
Network Configuration Manager
SQL Sentry
Web Help Desk
Free Tools & Trials
Store
Home
Products
Beta Alert Manager Condition Groups
DGoodale
I'm trying to get the hang of the COMPLETELY different Alert Manager. I understand how the condition groups work now BUT, if I create more condition groups after the first one, what relationship does it have to the first? Is it "and"ed, is it "or"ed or what? I'd like to control what the relationship is between the groups but I don't see a way to affect whatever the default condition is.
Dan Goodale
Find more posts tagged with
Accepted answers
All comments
aLTeReGo
Agreed.. I would love to see some examples of someone using advanced conditioning. It seems pretty powerful, but I can't grasp the concept without some examples.
DGoodale
Yeah, I'm getting so exotic with my attempts that I'm getting warnings and the alerts can't be saved. As you said, a few examples with multiple conditon groups would be WONDERFUL !!!
FormerMember
I'll see if I can do this justice by typeing it...I've gotten nested conditions to work fairly well.
Trigger Alert when ALL of the following apply:
Node Stautus is equal to Down
Trigger Alert when ANY of the following apply:
NodeType is equal to Cisco_VPN
NodeType is equal to Nortel_VPN
(NodeType is a custom propery I added to the database)
The way I have this working logic wise is it ANDS the down status and whichever of the second condition apply, so the trigger when ANY is an OR. By nesting conditions like this in different orders you should be able to do whatever you need.
Hmm, the formatting got hosed on that...the Node status line and trigger any line should be right underneath each other and the two node type lines should be lined up but further indented under the trigger any line.
The biggest catch I've found, is make sure you have the condition highlighted that you want to add the new condition under, otherwise it orders them improperly.
DGoodale
Yup....exactly!
I opened a ticket and was sent an example that resolved my confusion. As Ranger indicated, you create your AND/OR/NAND/NOR condition first and THEN you nest the rest of the conditional groups under it. Works like a charm!
Quick Links
All Categories
Recent Posts
Activity
Unanswered
Groups
Help
Best Of
