Community
Command Central
MVP Program
Monthly Mission
Blogs
Groups
Events
Media Vault
SolarWinds Academy
Products
Goal Oriented AI
Observability
Application Management
IT Security
IT Service Management
System Management
Database Management
Content Exchange
SolarWinds Platform
Server & Application Monitor
Database Performance Analyzer
Server Configuration Monitor
Network Performance Monitor
Network Configuration Manager
SQL Sentry
Web Help Desk
Free Tools & Trials
Store
Home
Products
Looking for possible variables like ${NodeID}
cschear
I quickly noticed that the "Custom HTML" and "User Defined Links" were global and not specific to each Node. I was intending on putting in some specific links and information, unique to particular Nodes. In order to retain the uniqueness of the information in these two Node fields, I need a full list of possible variables that can be inserted into the text, such as "${NodeID}.
That way, I can make global links that are uniquely created (i.e.)
"">www.google.com/search
I imagine there are such things as "${NodeDescription}" and "${NodeVendor}" but am also needing to know if any of the Custom Properties can be referenced. For example, I created a custom property called "Campus_PVC". Is there a way for me to reference that value with variables? I'd also like to know if the custom property NAME can be modified when viewing it in the Node Details page. I'd like to remove the underscores so properties such as "LAN_WAN_Deployment" can be viewed as "LAN/WAN Deployment", etc.
Did a search of the forums and knowledge base and couldn't find any references. Can someone provide me with a comprehensive list of all possible variables?
Thanks in advance.
Find more posts tagged with
Accepted answers
All comments
Mithrilhall
Use the Custom Property Editor.
When creating a Custom Property on a node it gets stored in the Nodes table and when you create a Custom Property on an interface it gets stored in the interface table.
So, if you created a Custom Property of IPAddy on the Interfaces you could access this by ${IPAddy}.
EDGOBEILLE
From Report Writer, select a report, then click on the report menu option and select SQL. This will reveal lots of SQL variables that are in use and can be used for creating filters of all types and other custom reports, custom properties etc.
Ed Gobeille
Quick Links
All Categories
Recent Posts
Activity
Unanswered
Groups
Help
Best Of
