Community
Command Central
MVP Program
Monthly Mission
Blogs
Groups
Events
Media Vault
SolarWinds Academy
Products
Observability
Application Management
IT Security
IT Service Management
System Management
Database Management
Content Exchange
SolarWinds Platform
Server & Application Monitor
Database Performance Analyzer
Server Configuration Monitor
Network Performance Monitor
Network Configuration Manager
SQL Sentry
Web Help Desk
Free Tools & Trials
Store
Home
Products
Monitor Polling Engines
jonchill
Is there anyway of getting the Monitoring details onto the Orion website, I know you can export it but that's just a snapshot it's not updated.
Anyone done this?
Jon
IT Infrastructure Manager
Pilgrim Hospital
UK
Find more posts tagged with
Accepted answers
All comments
Network_Guru
quote:I know you can export it but that's just a snapshot it's not updated.
I'm sorry Jon, but I beg to differ.
Any report created with Report Writer is "real time" as the ASP code on the web report page will refresh the info from the DB according to the setting you have in your web admin page (might also be set in the reports.asp code).
My reports update every 3 minutes, including Status Icons in the reports.
I don't quite understand what you mean by "Monitoring details".
There is a Polling details (or Stats) you can add to any page, which shows you the status of the polling engine & last time the DB was updated?
Can you be more specific as to what monitoring details you are after?
-=Cheers=-
NG
jonchill
NG, I know the report writer updates with the refresh setting on the website what I'm talking about is a seperate program that was installed with v7.8 that displays all your pollers and SQL server on a single page, with the status of the services running on the pollers. This would be useful info to be able to look at on the Orion site rather than having to open a seperate programe to look at the details.
Jon
Pilgrim Hospital
UK
Quick Links
All Categories
Recent Posts
Activity
Unanswered
Groups
Help
Best Of
