A server SAM with a license ALX can to monitor elements ( components)? 10k or 20k
If you're asking how many components you can monitor with ALX, there is no limit outside the limitations of your hardware- looking at Polling Engines under Settings will tell you how taxed your polling engines are, and as long as those numbers look healthy, there is no real set limit to the number of components for a SAM ALX license- it's the "unlimited" tier just like NPM SLX or UDT UTX.
https://support.solarwinds.com/?title=Success_Center/Server_Application_Monitor_(SAM)/Documentation/Scalability_Engine_Guidelines_for_Server_%26_Application_Monitor http://www.solarwinds.com/documentation/en/flarehelp/SAM/content/sam-licensing-sw175.htm
10 to 12 thousand components at default polling rates before some throttling will take affect (back end increase in poll time). You can go over that number, but you will see increased load on the server, and you will experience delays on the poll times (it will slowly increase to account for the additional burden on the server). That being said, one of the things that most people do not take in account is the health of the over all system in regards to the polled component monitors. If you have a ton of component monitors that are in a down/unknown state, it will very adversely affect the system and its ability to poll/keep up (due to clogging in the job engine SDF files). Healthy environments will be able to get away with much more than an environment that has a lot of bad states in it.
Hope this helps .
nathan.hejnicki ´So I need o monitor 22000 components.
Thank you .
Hardware limitations.
