Community
Command Central
MVP Program
Monthly Mission
Blogs
Groups
Events
Media Vault
SolarWinds Academy
Products
Goal Oriented AI
Observability
Application Management
IT Security
IT Service Management
System Management
Database Management
Content Exchange
SolarWinds Platform
Server & Application Monitor
Database Performance Analyzer
Server Configuration Monitor
Network Performance Monitor
Network Configuration Manager
SQL Sentry
Web Help Desk
Free Tools & Trials
Store
Home
Products
V7.7 Syslog Severity/Facility Blank?
lmtaudi
Hi All,
Upgraded to Version7.7 this morning which went without a hitch. I added the Sylog page to the customized views so I get the link at the top of the page. All looks OK apart from the fact that if I click on the drop down menu for either Severity or Facility there are no options (just says 'All Facilites' or 'All Severites')?
Also, if I go onto the Server itself and go to Syslog Server, Add New Rule, both of these fields are blank (i.e. there are no options to check)? It's as though I need a plug in to install these extra options...
Has anyone come across this issue or have any ideas?
Leon
Find more posts tagged with
Accepted answers
All comments
BryanBecker
I see the same issue.
BB
praghubar
Leon,
I had the same problem, and solarwinds support responded with Re-run the configuration wizard.It fixed the problem
Peter
lmtaudi
Contacted Solarwinds and as you said, re-running the configuration wizard solved the problem...bit odd but it worked!
Dagwood
Thanks for posting this folks. I had the same issue and was happy to see the thread. Especially since it's a little past quitting time on the eve of a Long weekend.
Quick Links
All Categories
Recent Posts
Activity
Unanswered
Groups
Help
Best Of
