We have added address information as Custom Attributes to nodes at each location. While this works, it really doesn't make sense from a management standpoint. I would like to create a location table that I can use to pull this information into a resource on the detailed node screen. I have a few questions:
1. Is it OK to add a custom table to the NPM database, or should it be created in a separate database?
2. Is there any info on building a custom resource that will query my custom location table using an attribute in the nodes table (SiteName)
3. Has anyone done something similar that can offer tips?
-=Dan=-
