Community
Command Central
MVP Program
Monthly Mission
Blogs
Groups
Events
Media Vault
SolarWinds Academy
Products
Observability
Application Management
IT Security
IT Service Management
System Management
Database Management
Goal Oriented AI
Content Exchange
SolarWinds Platform
Server & Application Monitor
Database Performance Analyzer
Server Configuration Monitor
Network Performance Monitor
Network Configuration Manager
SQL Sentry
Web Help Desk
Free Tools & Trials
Store
Home
Products
Monitor port 80
Debbi
Is there any way, without having to have the whole application mon pack, to see if a port 80 connection is responding? We only need to do a port 80 check on one node outside of our network to see if our firewall has stopped processing port 80 connections. -Debbi
Find more posts tagged with
Accepted answers
All comments
Geilt
I don't know of a way to check specific ports on a host using Orion without having to do some scripting on the remote HTTP server.
You could configure your firewall to send system messages to the Orion syslog system. If you start getting HTTP Denied messages you trip an alert to notify the appropriate people. You can refine your alert to only include HTTP denied messages that also include the IP address of the remote host you want to monitor TCP80 on.
If you're worried about the size of the Syslog DB growing too large you can filter out unrelate messages and have them deleted. Look in the Syslog Manager application on how to this part.
Grabowski
Application Monitor Pack isn't able to monitor a certain port (80). It checks if processes/services are running.
Lars Grabowski
Global Infrastructure
Chr. Hansen A/S
Currently using:
Cirrus Version 2.1 DL-500 Feb. 2006 (8.1.42)
Orion Application Monitor 7.8.94
Orion Web Engine Version 7.8.133
Orion NPM SLX 7.8.5 March 2006
Alert Manager 8.1.15
Quick Links
All Categories
Recent Posts
Activity
Unanswered
Groups
Help
Best Of
