Dear All,
Am facing a problem with Map icons post reboot of the orion NMS server.
The map objetcs have gone blur, i have attached the map snap for your reference.
Kindly help.
Thanks & RegardsVinod Dhure.
Vinod,
What size are you attempting to display these icons in?
We've increased the jpeg resolution in 9.5. Why don't you try upgrading and see if that fixes your issue?
