Community
Command Central
MVP Program
Monthly Mission
Blogs
Groups
Events
Media Vault
SolarWinds Academy
Products
Goal Oriented AI
Observability
Application Management
IT Security
IT Service Management
System Management
Database Management
Content Exchange
SolarWinds Platform
Server & Application Monitor
Database Performance Analyzer
Server Configuration Monitor
Network Performance Monitor
Network Configuration Manager
SQL Sentry
Web Help Desk
Free Tools & Trials
Store
Home
Products
Trouble Installing 7.7 with Win 2003 SP1
popper98
I'm wondering if anybody else has encountered this problem and found a solution:
Environment: Windows 2003 Server Enterprise Edition, SP1 + latest security patches, IBM 336 w/ 72GB SCSI, 4GB RAM.
Installed Orion 7.7 along with the MSDE SQL server without a problem. I try and launch the configuration wizard and ... nothing. Starting task manager I see that NetPerfMon-Wizard.exe starts up, times out, then dies. I also see a drwtsn32.exe process kick off slightly after starting the wizard.
Reviewing the DrWatson log reveals an 'application exception' in NetPerfMon-Wizard.exe.
I have un-installed and re-installed several times with the same results.
I have also sent an e-mail to support.
Find more posts tagged with
Accepted answers
All comments
popper98
Answer as provided by SolarWinds support:
1. Right mouse click on My Computer and select Properties.
2. Select the Advanced tab, click the Performance button, and then click the Settings button.
3. In Performance Options, click the Data Execution Prevention tab, and then click Add.
4. In the Open dialog box, locate ../Program Files/SolarWinds/Network Performance Monitor V7/NetPerfMon-Wizard.exe.
5. Click Open, click Apply, and then click OK. When you are prompted to restart your server, click OK.
alteon180e
thanks for posting the support response. This is the second time i have been sideswiped by DEP......I have to get back to reading readme's
Quick Links
All Categories
Recent Posts
Activity
Unanswered
Groups
Help
Best Of
