Hello,
Is TippingPoint devices supported by Kiwi CatTools ???
Hi Creativity44:
CatTools doesn't support TippingPoint devices - you can see the list of supported devices here: http://www.kiwisyslog.com/wrapper/devices-supported/. However, if you can post a PuTTY capture of logging into the device and generating a backup, one our our developers said he'd be able to look and tell you if one of the existing templates would work. (Please *** out any sensitive data from the PuTTY capture).
--Christine
