Community
Command Central
MVP Program
Monthly Mission
Blogs
Groups
Events
Media Vault
SolarWinds Academy
Products
Goal Oriented AI
Observability
Application Management
IT Security
IT Service Management
System Management
Database Management
Content Exchange
SolarWinds Platform
Server & Application Monitor
Database Performance Analyzer
Server Configuration Monitor
Network Performance Monitor
Network Configuration Manager
SQL Sentry
Web Help Desk
Free Tools & Trials
Store
Home
Products
Hyper-Threading (on or off)
Mithrilhall
I'm curious....
We have a Dell PowerEdge 1850 (Dual Xeon processors) with Hyper-Threading enabled. This makes the server look like it's running 4 processors, which...allows any process running to take up to 25% CPU but no more.
When I start the server the NetPerfMonServi goes right to 25% and stays there. I then start the Orion System Manager and it takes quite a long time to for it to fully load (sometimes up to 20 minutes or more) and this is not counting the Baseline Calculation.
So my question is...Would it help if we turned off Hyper-Threading so NetPerfMonServi could use more CPU? I'm hoping this will speed up Orion System Manager.
Find more posts tagged with
Accepted answers
All comments
BK
Turning off Huper-Threading will probably not help. You are fulling using the processor, it is just that the OS is dividing by 4 instead of 2 when reporting.
If you are running less that the 7.8 build of Orion. I would suggest you upgrade. A few changes where made to the system manager so it could pull information directly from the database instead of the service during startup. Also, to improve the load time in 7.8, the Node Tree, on the right side of the system manager was changed to dymically load subtrees as needed instead of building the entire Node tree at startup.
BK
Nobody Special
Mithrilhall
Thanks.
I'll download 7.8 and do the upgrade today.
Much appreciated.
Quick Links
All Categories
Recent Posts
Activity
Unanswered
Groups
Help
Best Of
