Community
Command Central
MVP Program
Monthly Mission
Blogs
Groups
Events
Media Vault
SolarWinds Academy
Products
Observability
Application Management
IT Security
IT Service Management
System Management
Database Management
Goal Oriented AI
Content Exchange
SolarWinds Platform
Server & Application Monitor
Database Performance Analyzer
Server Configuration Monitor
Network Performance Monitor
Network Configuration Manager
SQL Sentry
Web Help Desk
Free Tools & Trials
Store
Home
Products
NET SNMP v5.0.9
sshukri2000
we have several Sun servers running solaris 5.9, I am in need of NET SNMP v5.0.9 agent in order to be able to monitor cpu and memory
I tried to find in the internet but couldn't get that version. anybody knows where can i find it.
thanx
Find more posts tagged with
Accepted answers
All comments
chris.conway
go here for all versions
http://prdownloads.sourceforge.net/net-snmp
Analyser Sales Ltd
SolarWinds Premier Partner
www.asl-solarwinds.co.uk
BryanBecker
Has anyone tried the newer versions? We are running into this now and I know 5.0.9 workjs but it is a little older. Can anyone validate a later version that is working?
Thanks.
BB
CCrew
quote:
Not here.. We've tried an awful lot of versions too, always something "not quite right"
-Roger
lavelanet
Ditto every other newer version I tried doesn't work. I beleive it has to do with the fact that solar winds querys off a depreciated item in 5.0.9 that was removed after that version. I've gotten nothing for answers when I've asked about their support for an updated version and I've always assumed that since V8 is supposed to support custom mibs they plan on doing away with the need for net-snmp in the future.
Just my two cents and WAGs
mjhamilton
I am a long sufferer of the Orion/net-snmp compatability problems..... I have tested all version and the only one that will work is 5.0.9
. don't even bother with the other versions... they all do someting different but the bottom line is that they are unstable and will keep crashing... for example 5.1.1 works great for CPU, Mem and network however as soon as you poll a disk then bang the agent crashes)...
Stick with 5.0.9.. it works well on all platforms... it may be old but hey if it ain't broke then don't fix it!!
Is there anyone from Solarwinds that would like to comment about future support for Unix based systems in the future?!?!?!... I mean v8 is on the way so what is going to happen going forwards??
Martin J. Hamilton... lost in a sea of snmp...
Mithrilhall
Martin
How do you monitor the disk? What needs to be added to my snmpd.conf?
I'm running 5.1.4.
Mithrilhall
Okay...I'm now running v5.0.9 and I still am not seeing the disk volumes listed.
If I do a snmpwalk I see my 2 disk volumes but for some reason Orion is not picking them up. Does anyone have any suggestions?
mjhamilton
have you tried to redefine the resources within the management tools iteself... there is nothing required in the snmpd.conf file if you see CPU and mem then this is working ok...
Open the Orion management tool, right click on the device and goto the resource tab.... you should now find disk listed in the available options
Mithrilhall
Well...using a MIB Browser I can see this:
1 / /dev/hda2 10000 -1 18374532 15812292 1628864 ...
2 /boot /dev/hda1 10000 -1 101086 87389 8478 9 0 ...
Orion on the other hand only shows CPU, Memory, eth0, lo and sit0...and I'm using Net-SNMP 5.0.9.
Alfred
I have the same problem with an HP-UX system. I installed the: ixNet-SNMP A.06.00-5.2.1.2 Simple Network Monitoring protocol. The onlything I can see is CPU/Memory/Network devices within SolarWinds Orion. What is wrong ??
Quick Links
All Categories
Recent Posts
Activity
Unanswered
Groups
Help
Best Of
