Community
Command Central
MVP Program
Monthly Mission
Blogs
Groups
Events
Media Vault
SolarWinds Academy
Products
Observability
Application Management
IT Security
IT Service Management
System Management
Database Management
Content Exchange
SolarWinds Platform
Server & Application Monitor
Database Performance Analyzer
Server Configuration Monitor
Network Performance Monitor
Network Configuration Manager
SQL Sentry
Web Help Desk
Free Tools & Trials
Store
Home
Products
Port Labelling
jonchill
I've just labelled our switch ports on our core switch and want Orion to update it's port labelling but cannot work out how to do it, can it be done without having to remove and re-add the device?
Jon
IT Infrastructure Manager
Pilgrim Hospital
UK
Find more posts tagged with
Accepted answers
All comments
aLTeReGo
Your core switch isn't running CatOS is it?
Mithrilhall
Right-click the Node in the Orion System Manager and choose "Node Details". This give you the option to "Rediscover". I'm not sure that does what you want but it's worth a try.
iceman
Move from CATOS to Native IOS.
This will solve your problem.
jonchill
Nope not running CATos it's a 3COM core (No chuckling now) I did a re-discover in the node details but nothing happened, so I left it and after a couple of hours the port descriptions changed.
Does the re-discover node not run straight away?
Jon
Pilgrim Hospital
UK
Isaac
Hi there Jon,
You would have to do a manual rediscover on every one of the interfaces you had monitored on that switch in order to update the interface descriptions in SW.
Alternately you can just wait for SW to do its rediscovery of all nodes, interfaces, and volumes (defaults to every 180 minutes).
Be fantastic
Quick Links
All Categories
Recent Posts
Activity
Unanswered
Groups
Help
Best Of
