The organization I work for is the eighth largest school district in the country. We have approximately 25,000 employees servicing approximately 280,000 students in grades 1 - 12. Our organization is spread over close to 400 buildings, all networked, each having hundreds of nodes (switches, computers, hand-held devices...etc.).
We just purchased the following modules:
Orion Additional Polling Engine -2017.03.14
Orion Netflow Traffic Analyzer - SLX-4.2.3
Orion Network Configuration Manager v7 - DLX-7.7.0
Orion Network Performance Monitor SLX-12.2.0
Server & Application Monitor - ALX-6.4.0
Database Performance Analyzer - Category1 - Oracle EE or ASE or DB2 (5 to 9 instances)-11.0.1.1018
Engineer's Toolset for Desktop-11.0.6
Engineer's Toolset for Web-11.0.6
Web Performance Monitor - WPM50-2.2.1
I was not involved with the selection of these modules. I am tasked with creating the servers in our VMware environment. My background is in programming, VMware, DBs and MS System Management. I read the requirements doc for NPM. At this point, I know I need a main Orion server and a DB Server (SQL Server).
Questions:
1. Do each of the modules (NPM, SAM, WPM) need their own application server and corresponding DB server or can all the modules reside on one main server and one DB server (w/ multiple DBs)? What would be the recommendation for an organization of our size?
2. As far as the Polling servers, is it a separate server or is it a server that has the Agent installed on it? Could we use our Domain Controllers as Polling servers?
3. What documentation would you recommend for me to start out with? I am looking on the Solar Winds Customer Portal at the NPM documentation. I also quickly looked at the System Application Monitor documentation in the Portal.
4. Is there an ERD/Diagram of the entire Orion Platform?
I hope this will get me started. I appreciate any help that anyone can give me.
Scott
