Community
Command Central
MVP Program
Monthly Mission
Blogs
Groups
Events
Media Vault
SolarWinds Academy
Products
Observability
Application Management
IT Security
IT Service Management
System Management
Database Management
Content Exchange
SolarWinds Platform
Server & Application Monitor
Database Performance Analyzer
Server Configuration Monitor
Network Performance Monitor
Network Configuration Manager
SQL Sentry
Web Help Desk
Free Tools & Trials
Store
Home
Products
Cascaded Email Alerts
rwrussell
We are using Orion Performance Monitor to monitor our network and have set up email alerts for node status changes. The email is sent to our cellphone as a text page.
There are many devices being monitored that are behind other devices and this continues to cascade down the network. For example, if router C goes out, all the devices behind it are also offline. If router B goes out, then all the devices behind it including everything behind router C are offline, etc.
Is there a way to set up the alerts so that if any device goes offline, a page goes out for that node, but if a device with nodes behind it goes down, only a page for that node goes out, rather than a page for every device behind it?
Find more posts tagged with
Accepted answers
All comments
Network_Guru
Yes it's called alert suppression.
If you do a search for this, you will find many posts on this subject.
Here's one to get you started (make sure to check the last few posts in this thread).
www4.solarwinds.net/.../topic.asp
-=Cheers=-
NG
[url="
http://www4.solarwinds.net/SolarWindsForum/search.asp
Quick Links
All Categories
Recent Posts
Activity
Unanswered
Groups
Help
Best Of
