Community
Command Central
MVP Program
Monthly Mission
Blogs
Groups
Events
Media Vault
SolarWinds Academy
Products
Goal Oriented AI
Observability
Application Management
IT Security
IT Service Management
System Management
Database Management
Content Exchange
SolarWinds Platform
Server & Application Monitor
Database Performance Analyzer
Server Configuration Monitor
Network Performance Monitor
Network Configuration Manager
SQL Sentry
Web Help Desk
Free Tools & Trials
Store
Home
Products
Capture Data On a Monitored port on Cisco Switch
kindbro
I am running the lastest version of Orion and my switch is a 6513, running a span and would like to monitor it for bandwidth. Since solar winds Orion does not monitor down interfaces for traffic flows it makes it difficult to gather data that I no is taking place.
This port is not down, cisco shows it as up/down (monitoring) which means that it is doing what its suppose to, gather data from all ports on the switch to this destination port. If i run a bandwidth guage against the same port, the guage reflects spikes of data at any where from 300mbps - 800mbps. Has anyone been able to get Orion to gather data from a span port on a cisco switch?
Thanks in advance
Find more posts tagged with
Accepted answers
All comments
jkbonds
From SolarWinds support:
Orion looks at the IFTable (OID 1.3.6.1.2.1.2.2) when checking interfaces and nodes. If the report responds to this as up, Orion can monitor it, if the device reports to this as down, then it shows as down, and all Orion will do is poll it for status. There would be no way to collect the information you are looking for unless the interface were to report as up.
J Kevin Bonds
AT&T
Quick Links
All Categories
Recent Posts
Activity
Unanswered
Groups
Help
Best Of
