Community
Command Central
MVP Program
Monthly Mission
Blogs
Groups
Events
Media Vault
SolarWinds Academy
Products
Goal Oriented AI
Observability
Application Management
IT Security
IT Service Management
System Management
Database Management
Content Exchange
SolarWinds Platform
Server & Application Monitor
Database Performance Analyzer
Server Configuration Monitor
Network Performance Monitor
Network Configuration Manager
SQL Sentry
Web Help Desk
Free Tools & Trials
Store
Home
Products
Is there way to change which MIB's are looked at?
tekkie
Hey guys newbie here :-/ Just purchased orion and while I was evaling it I did not test something that I should have. We have SNMP4NT setup on some of our NT 4 servers so we can monitor Exchange, SQL etc.. with Orion I have no way of seeing any of this. Is there a way that I can modify the server object so I can put in these counters that I need access to?
sorry I looked around here for a while and dont see the answer
Find more posts tagged with
Accepted answers
All comments
Network_Guru
Unfortunately not.
That is one feature lacking that a lot of users have asked for.
Do a search in this forum for "custom mib" - exact phrase.
Here are some results:
www2.solarwinds.net/.../topic.asp
-=Cheers=-
NG
iunderwo
Custom MIB support has been an often-requested feature from the Orion package. Orion generally monitors standard MIBs for systems, interfaces, and volumes...with a couple of Cisco extensions included for good measure.
MIBs cannot be changed, simply due to the table structure in the database. The tables are generated around the MIB parameters, and are not changable in the core application.
You'll need to use another program to monitor application status for the time being.
// Ian Underwood - Service Management
// Level 3 Communications
Quick Links
All Categories
Recent Posts
Activity
Unanswered
Groups
Help
Best Of
