Hi guys, i have currently configured a frame relay lab in dynamips consisting of two routers, a frame relay switch and two clouds to which i have connected two vmware virtual machines (one at either end).
I now want to monitor the traffic between them using NPM, i understand this works via SNMP so that will need to be configured on both routers.
Once this is done will i then be able to use the netflow configurator?
