Community
Command Central
MVP Program
Monthly Mission
Blogs
Groups
Events
Media Vault
SolarWinds Academy
Products
Goal Oriented AI
Observability
Application Management
IT Security
IT Service Management
System Management
Database Management
Content Exchange
SolarWinds Platform
Server & Application Monitor
Database Performance Analyzer
Server Configuration Monitor
Network Performance Monitor
Network Configuration Manager
SQL Sentry
Web Help Desk
Free Tools & Trials
Store
Home
Products
Engineer's Toolset
switchport mapper/3548 clusters
Edpbrennan
It seems the switchport scanner will only scan the masters of each of my switch clusters. Is there any way I can get it to scan the slave switches? Some of these slaves have IP addresses and community strings, but the switch scanner says they are unresponsive.
Ed Brennan
Dir. Computer Resources
Albany Law School
Find more posts tagged with
Accepted answers
All comments
Bryan
Switch clusters. I used to have about 8 switch clusters in my network. They were catalyst 3548. I walked in to the network after it was already built and the first thing I did was un-cluster those switches. I thing management is much easier with individual managed switches. Just my thought on the subject. I didn't have SolarWinds deployed at the time I had the clusters active..
Sorry
Lockheed Martin
Atlas V Launch Operations
Network Engineer
snowjay
You can always just leave the switches clustered and just add an ip address to the other switches. This way CiscoView will still see the cluster and show all the switches to you but you still have individual ip's that other managment tools can use. I prefer the CLI myself so ip's on everything is the way I go.
Jay
Bryan
Agreed, CLI is the only way to go when configuring a network. But products like solarwinds do make gathering statistics much easier! For the longest time I used MRTG and a program called Big Brother, my only issue then MRTG was that you couldn't pull historical data from it. I like to be able to go back and zoom in on a certain period of time.
Lockheed Martin
Network Engineer
dclick
So, short of adding IP's to my cluster members, there is no other option? (aside from CLI, which I also perfer.)
tharder
I beleve Cisco has also been removing the cluster software from the newer versions of IOS for those devices as well...
Quick Links
All Categories
Recent Posts
Activity
Unanswered
Groups
Help
Best Of
