Hello,
Is there a way to determine when a device was added to monitoring? I have many devices for a customer and they would like to know when every device was added. It has easily been over a year.
Thank you,
David
If you have version 10.4.2 of NPM, you can run an audit report that will show this information. If you want only to see the "node added" data, then you can edit the report to filter for "Action Type= Node Added".
The audit report will be dependent on how long you retain data as well.
