Community
Command Central
MVP Program
Monthly Mission
Blogs
Groups
Events
Media Vault
SolarWinds Academy
Products
Observability
Application Management
IT Security
IT Service Management
System Management
Database Management
Content Exchange
SolarWinds Platform
Server & Application Monitor
Database Performance Analyzer
Server Configuration Monitor
Network Performance Monitor
Network Configuration Manager
SQL Sentry
Web Help Desk
Free Tools & Trials
Store
Home
Products
Engineer's Toolset
Bulk change interface bandwidth setting
dspringer
In Network Performance Monitor is there a way to change the bandwidth settings for all interfaces of a particular type (like FastEthernet or GigabitEthernet)? I have over 1000 FastEthernet interfaces that were discovered at 10Mb bandwidth, so I'm getting those erronious over 100% useage messages. So far most of the Gigabit interfaces were detected with the correct bandwidth setting, but I'm not about to go and manually reset the settings for over 1000 switchports.
This seems to only have happened on the Cisco Catalyst 3560 switched we have. The 2950 switches have the correct bandwidth settings detected.
I should also mention that I have no fear of going in and modifying the database directly if need be. Whatever the solution may be I'm sure it's easier than manually modifying 1000+ entries.
Thanks!
Derrick Springer
Network and Telecom Administrator
Soka University of America
Find more posts tagged with
Accepted answers
All comments
Network_Guru
You can edit the DB directly using the Orion database manager app.
Have a look at these posts:
www2.solarwinds.net/.../topic.asp
As per the last post, you most shutdown the Orion service while doing the update & then restart it when done.
-=Cheers=-
NG
dspringer
Thank you for the information. Unfortunately I am not running Orion, I'm using the NPM from the Engineer's Toolkit (we are contemplating the purchase of Orion, but at this time this is the best I've got). Since I'm not running SQL I do not think the solutions you provided will work. Can the db in the Engineer's Toolkit version be directly modified or am I out of luck?
Network_Guru
You might be able to do this with MS Enterprise SQL manager.
I have not had much experience with NPM or managing the DB.
There are also other posts in this forum on managing the NPM DB.
-=Cheers=-
NG
chris.conway
Derrick,
The NPM database is actually an access file so as long you close down NPM, you could edit it in Access 2000 or above.
Just make sure to take a backup before you do though!!
Chris
Analyser Sales Ltd
SolarWinds Premier Partner
www.asl-solarwinds.co.uk
dspringer
Awesome, thanks for the tip. Going to have to give that a try.
Quick Links
All Categories
Recent Posts
Activity
Unanswered
Groups
Help
Best Of
