Community
Command Central
MVP Program
Monthly Mission
Blogs
Groups
Events
Media Vault
SolarWinds Academy
Products
Goal Oriented AI
Observability
Application Management
IT Security
IT Service Management
System Management
Database Management
Content Exchange
SolarWinds Platform
Server & Application Monitor
Database Performance Analyzer
Server Configuration Monitor
Network Performance Monitor
Network Configuration Manager
SQL Sentry
Web Help Desk
Free Tools & Trials
Store
Home
Products
Engineer's Toolset
more than 200 interface to monitor
arisdh
We purchased Solarwinds Engineer version and currently used to monitor more than 200 interfaces and would be more on PIII/900Mhz with 512Kbps RAM. The primary task is to monitor latency and connectivity between one site to our NOC. Currently my PC performance has extreemly degradated, Anybody can give suggestion what is the best configuration to coupe with this requirements.
Find more posts tagged with
Accepted answers
All comments
Bryan
arisdh,
I am runnig a P4 1.7Ghz with 1gig of memory. For the most part, the PC runs fine. On occasion, when accessing the Network Performance Monitor, I do experience some lag.. I am monitoring 35 nodes and 538 interfaces. If you are monitoring 200 "nodes" I can see where you system may have problems. Maybe you would be better off with a newer system with Hyper-Threading? Are you running more then the NetPerfMon? I have the NetPerfMon, Advanced CPU Load monitor and they syslog server as well as another monitor application called big brother.
Lockheed Martin
Atlas V Launch Operations
Network Engineer
DannyMc
I'm not monitoring as many nodes as Bryan but I'm using a Dell SX270 (2.4g / 512meg). I'm only monitoring about a dozen nodes and close to 50 interfaces. I am monitoring uplinks to stacks off my core, WAN links and interfaces for two AS/400's. I am running Network Perf Monitor & Bandwidth Monitor for this stuff. I also run Adv CPU Monitor for 13 devices.
I am also running Kiwi Syslog for my Pix, 3005 VPN Concentrators and CE510 Content Engines. As you can imagine, this generates a lot of small packets of network traffic.
I also run SmartFilter Admin server on this machine.
After 239 days running, I had to reboot this system last night. Impressive for a Windows box running multiple applications.
Advanced CPU monitor never shows this box going over 22%. Usually floats around the single digits for CPU.
I am in the process of getting a separate system to split out the Solarwinds Admin server and leave this box dedicated to network monitoring.
As you can see, you can throw a lot at a cheap box.
Hope this helps.
Danny Mc?
Quick Links
All Categories
Recent Posts
Activity
Unanswered
Groups
Help
Best Of
