I'm just looking at moving our config downloads from Telnet to SNMP and TFTP and while the file is downloaded correctly to the Cirrus database I noticed there's also a file downloaded to the TFTP folder which is not named or formatted correctly, what is this file for and can it be safely deleted?
Also I've noticed that the switch I was testing this on has now had node monitoring enabled and the only way I can turn it off is to turn it on and then off again, does SNMP transfer require node monitoring to be enabled?
Jon
