When i use cattools to access my HP Procurve 2626 and 2650 Swiches, I get failures being caused by a inital login line that is not accounted for in the Cattools configuration. When you log into the switches you get a splash screen that says press any key to continue and then you get the login screen. HOw can I create a script to enter a character and wait so that Cattools can login correctly? I ahve been told the splash screen can not be disabled. So when telnetting to the switch the 1st screen is not the username prompt.
