Community
Command Central
MVP Program
Monthly Mission
Blogs
Groups
Events
Media Vault
Products
Observability
Application Management
IT Security
IT Service Management
System Management
Database Management
Content Exchange
SolarWinds Platform
Server & Application Monitor
Database Performance Analyzer
Server Configuration Monitor
Network Performance Monitor
Network Configuration Manager
SQL Sentry
Web Help Desk
Free Tools & Trials
Store
Home
Products
Router BGP Monitoring
mpearson
Just a suggestion, it would be really handy if Orion could monitor the status of BGP peering sessions, it is an industry standard MIB... Just through i'd throw it out there. I've seen a dozen posts asking about this.
Find more posts tagged with
Accepted answers
All comments
Isaac
Someday in the not too distant future the kids at SW will provide support for custom MIBs. All of our questions about lack of vendor support (Nortel, Foundry, Extreme, HP, Dell, etc...), and about technology support (VPN, BGP, ISDN, IP Voice, etc...), and physical monitoring (fans, temp, power, etc...) will fall away and we will reach a state of network monitoring nirvana.
Until then keep posting. Eventually the weight of the posts will force the issue.
Be fantastic.
iunderwo
Agreed. That would be extremely useful to have. Add a few other routing protocols, and it could potentially be a handly add-on pack.
// Ian Underwood - Network Engineering
// Boston Stock Exchange
larry.rice
I think allowing custom MIBs would rock. anyone could do anything they needed. completely customizable. Doesn't get any better than that!
Larry
mpearson
I am not even talking custom MIB on this one. Although yes its desperately needed. I'm talking integration, like there is the "application monitoring" add on. Having the ability to monitor Routing-Peer status as a supported report/view/etc would be huge.
Network_Guru
Here's a "Temporary" workaround until we get our custom MIB reporting:
You could enabling logging of BGP peer changes on your router & send them to the Orion Syslog. You should then be able to create a custom report in Report Writer, to view this data.
-=Cheers=-
NG
Quick Links
All Categories
Recent Posts
Activity
Unanswered
Groups
Help
Best Of
