Community
Command Central
MVP Program
Monthly Mission
Blogs
Groups
Events
Media Vault
SolarWinds Academy
Products
Observability
Application Management
IT Security
IT Service Management
System Management
Database Management
Content Exchange
SolarWinds Platform
Server & Application Monitor
Database Performance Analyzer
Server Configuration Monitor
Network Performance Monitor
Network Configuration Manager
SQL Sentry
Web Help Desk
Free Tools & Trials
Store
Home
Products
Install License key on temp copy or wait?
dsullinger
We have a 30 day install of Orion SLX. It timed out yesterday, but I also received our full license for SLX yesterday. We were testing it on a pretty under powered server. It was a dual 1GHz Xeon Proliant and we were monitoring about 400 nodes and just under 10k interfaces. We've ordered 2 new Proliant servers that both have dual 3.2GHz Xeon CPUs, one for SQL and the other for Orion.
Do you think we should just wait to install the new license key until we get the new servers? I noticed the license is tied to the server name and I know the new server will have a different IP and name.
Also, when I get the new server up and running, should we start a new discovery or can we just pull the database over from the temp copy?
Thoughts?
Thanks in advanced
Find more posts tagged with
Accepted answers
All comments
Network_Guru
It is extra work moving the database to another server, but if you have the time it
is not too hard. Once you get the new servers, you can just phone or e-mail Solarwinds
to reset your SLX license. Then you can install on the new server and be up in a matter of minutes. Make sure you have your database copied onto the new server before installing
the Polling engine and website on the other server.
Also, I have found there is a licensing conflict if you leave the old server up and running on the network. You will also have to run the Polling Engine Load balancer on the new server to change the Polling Engine ID in the new database, as well as running a query to
change the Alerting engine ID to the new server.
-=Cheers=-
NG
iunderwo
I'd say it's best to wait for the new boxes to arrive.
Since the database on the Eval is a SQL as well, it should be no problem to bring over. There are instructions in the admin manual.
I'd wait on virtue of 7.2 coming out very shortly.
// Ian Underwood - Service Management
// Level 3 Communications
BryanBecker
7.2 is now available on the website for registered users.
Network_Guru
Please check out this page before installing/upgrading:
www.solarwinds.net/.../OrionNPMUpdatesV7.htm
-=Cheers=-
NG
Quick Links
All Categories
Recent Posts
Activity
Unanswered
Groups
Help
Best Of
