Community
Command Central
MVP Program
Monthly Mission
Blogs
Groups
Events
Media Vault
SolarWinds Academy
Products
Goal Oriented AI
Observability
Application Management
IT Security
IT Service Management
System Management
Database Management
Content Exchange
SolarWinds Platform
Server & Application Monitor
Database Performance Analyzer
Server Configuration Monitor
Network Performance Monitor
Network Configuration Manager
SQL Sentry
Web Help Desk
Free Tools & Trials
Store
Home
Products
What is the main difference between EE and Orion?
Epsil0n
Hey everyone, I'm new here... Hi!
I am trying to figure out the main differences between the EE toolsets and Orion. It sorta looks like Orion has similar features as the EE-Network Performance Monitor... except that Orion publishes the information to a webserver in real time. Is that the main difference?
It seems like essentially you could just let the EE-Network Performance Monitor run on a box all the time and collect data. You would still have alerts, historical data, etc. If you needed to access the info from another computer you could just connect remotely via VNC, etc. Is that right?
Is there more to Orion that I am not realizing? What are the main selling points that people find useful that the EE tools don't offer?
Thanks!
Epsil0n
Find more posts tagged with
Accepted answers
All comments
DannyMc
Epsilon,
Your comment regarding EE and using VNC... I have that very setup today and have been doing it for 2 years now. Another product with EE that I use heavily is Switch Port Mapper.
Not only do I use EE and access it remotely with VNC, I just bought and installed a 500 node version of Orion. You are correct, it does basically the same thing but publishes it to web pages. I also bought a more robust server to go with it.
I bought EE on the cheap for around $1k. That was a year after I bought HP OpenView and CiscoWorks for around $30k and realized how complicated both were!! For what I needed, EE replaced OpenView and CW and it was cake to figure out. I do miss the VLAN listing of all IP's and Hosts across the entire network versus Switch Port Mapper doing only one switch at a time as well as Cisco configuration archival and scheduled configuration deployments. However, I cannot justify $20k plus for the later two items twice a year.
I added Orion:
1) To give others in my group visability to nodes, reporting, alerts, etc.
2) The mapping product to give visual representations to support staff.
3) Stores data in an SQL database. The MSJet database in EE can only hold so much.
4) I started to hit a breaking point with monitoring in EE. Database maintenance would cause monitoring to randomly stop.
5) Reporting
I'm waiting on the ability to define custom MIBs at this point. I have some devices that are not very common and would like to monitor SNMP elements of those devices. IE: The SNMP boxs that attach to my Exide UPS's. I would like to monitor power conditions, time on battery, spikes, load for planning purposes, etc.. I would also like to monitor aspects of my Avaya phone systems, AS/400's and what ever else business systems that I have deployed.
I spent more money on Orion than I did with OpenView but once I did the discovery, I got get WAY MORE information out of it box with Orion than I could figure out in OpenView after a year. The web presentation in Orion for management and support personell is WAY more intuitive than OpenView.
It all boils down to what you need and how deep your pockets are.
Network_Guru
Orion is an Enterprise Network Management Tool. EE is designed more as a Technical troubleshooting tool. Some Major differences;
Orion uses MS SQL DB, EE uses MSDE access DB(limited to 2Gb)
Orion has Report Writer
Orion has Report Scheduler
Orion has Custom Property Editor
Orion has a built in Syslogger
Orion has Custom Alerting
EE has Switchport Mapper
EE can graph custom Mibs
EE can scan your whole Network for IP's in use
EE can monitor your DHCP server scopes
EE can upload & download Cisco configs
[/list] Basically anything in the Orion DB can be displayed on a Web page. Most things in EE are viewed locally on the server - no easy way to run reports such as; -what nodes went down in the past month & for how long? -what was the 95th percentile utilization of a WAN over the past 90 days? It all depends on what info you are looking for. Most Enterprise Networks use both products, as they complement each other. -=Cheers=- NG
Epsil0n
Wow guys! I have to say a huge thanks for the comprehensive and well written responses!!! --your time to fill me in on the details is much appreciated!
I can now see the use in having both EE and Orion. I'm not sure we will want to invest in Orion... but the specific mention of Orion being able to show us 95th Percentile use of our WAN interface over the past month is very attractive.
One more question for now:
What counts as nodes in Orion? Is a node anything that it discovers that can be monitored via SNMP? Does the node count include all the computers/servers on the network? or is the term "node" limited to network devices such as switches, routers, firewalls, etc.? I'm just trying to figure out how much Orion would cost our institution based on how many "nodes" we have.
Thanks again for the amazing replies!
Epsil0n
Quick Links
All Categories
Recent Posts
Activity
Unanswered
Groups
Help
Best Of
