I know I can put a custom banner on the top of the gui to replace "SolarWinds" logo with another logo. Is it possible to also change headings like "Orion Summary Home"?
Yes to both
- to change the logo: Settings, Web Console Settings and the setting is called Site Logo URL
- to change the heading of a view, click on 'Customize Page' link, change the heading and click the Update button.
JohnnyFriendly,
Yes, you can just select the "Customize Page" at the right top of the Orion Summary Home.
Then on the next view, just adjust the name to what you want and select update. You will see the name change, then select submit at the bottom of the page to take you back out to the view.
Best Regards,
Derik Pfeffer
Thanks HG,
J.
solarwindscommunityteam@communications.solarwinds.com]
Sent: 24 September 2014 16:08
To: John Clifford
Subject: Re: - Can I change heading "Orion
Summary Home" to "<my company> Summary Home"?
thwack
in Network Performance Monitor - View the full discussion
<thwack.solarwinds.com/.../250889
J
Sent: 24 September 2014 16:19
<thwack.solarwinds.com/.../250866
