Community
Command Central
MVP Program
Monthly Mission
Blogs
Groups
Events
Media Vault
SolarWinds Academy
Products
Goal Oriented AI
Observability
Application Management
IT Security
IT Service Management
System Management
Database Management
Content Exchange
SolarWinds Platform
Server & Application Monitor
Database Performance Analyzer
Server Configuration Monitor
Network Performance Monitor
Network Configuration Manager
SQL Sentry
Web Help Desk
Free Tools & Trials
Store
Home
Products
mapmaker error runtime error '62'
view
i config the map through the terminal service .
when i use the mapmaker to build a map ,the error pop up ,say " run time error 62". can you give me some idea about the error ? thanks .
Find more posts tagged with
Accepted answers
All comments
iunderwo
More info is needed:
* Are you running Win2k or Win2k3?
* Are Terminal Services configured for administration only or users?
* Is the error occurring as soon as you start MapMaker or when you perform a certain action?
// Ian Underwood - Service Management
// Level 3 Communications
view
by the way,the error is the same through the console .
>win2k sp3
>config through the console ,the error is the same
>when i add a node,and save the map,the error pop up.
"run-time error '62': input past end of file"
or "error creating test.OrionMap input past end of file"
view
the problem is the node name i changed with the language "simplied chinese ".that's why the error pop up!!
i search the 'NetPerMon' database ,in the 'Nodes' table ,i can't find the 'Node name' segment,only 'SysName' segment is there.
so i guess when i change the 'Node name' with 'simplied chinese' in the 'System Manager',the 'Map Maker' behave abnormal.
suggest add 'Node Name 'segment in the 'Nodes' table .
the Orion v7 don't support the "simplied language" only use 'SysName',right ?
thks.
Quick Links
All Categories
Recent Posts
Activity
Unanswered
Groups
Help
Best Of
