Community
Command Central
MVP Program
Monthly Mission
Blogs
Groups
Events
Media Vault
SolarWinds Academy
Products
Goal Oriented AI
Observability
Application Management
IT Security
IT Service Management
System Management
Database Management
Content Exchange
SolarWinds Platform
Server & Application Monitor
Database Performance Analyzer
Server Configuration Monitor
Network Performance Monitor
Network Configuration Manager
SQL Sentry
Web Help Desk
Free Tools & Trials
Store
Home
Products
Events and Alerts
cabsandy
Hi all,
I'm trying to customise the alerts, putting in some alerts, adding new macros to existing alerts and editing existing ones.I do everything by the book but when I then look for the new alerts, I get nothing in the actual alert message.The alert comes up but the description field is blank.Looking back through the configure alerts tab, the message is definetly in there and all relevant tabs are ticked.
What is even weirder is that when I then go to the Events tab, the new alerts dont show up and the old alerts which I have disabled, still show up.I'm using NPM 7.1.
Has anybody seen this before? When you edit or add a new event, should the change happen straight away? Do you have to restart NPM?
Stew
Find more posts tagged with
Accepted answers
All comments
DGoodale
huh...I've never experienced what you're describing but, when weird stuff happens, a reboot usually solves the issue. If you're positive you created the action object and put the trigger and reset messages in the approppriate fields, it sounds like reboot time!
Network_Guru
It seems others have had this same issue.
I did a search for BAM (Beta Alert Manager) & found this solution:
www4.solarwinds.net/.../topic.asp
-=Cheers=-
NG
[url="
http://www4.solarwinds.net/SolarWindsForum/search.asp
Quick Links
All Categories
Recent Posts
Activity
Unanswered
Groups
Help
Best Of
