i have opened a case with Solarwinds, but haven't heard anything back from them as of yet. We have multiple MRV products in our networks that i would like to be able to use catttols to manage. But, for the life of me i can't get them to appear in the device types. I have followed the manual word for word and it doesn't seem to make a difference in creating the device. It just never shows in the list. most of the MRV we have are fiberdrivers, a few 9000s and a ton of 910s. The pre-built cisco device types don't work. They will not even login correctly. As many of you may know. the MRV ethernet is basically Cisco IOS with a few twists. I have got a backup config to the point where CatTools will now login, but that is it. I don't understand why it doesn't work. I have included the 'capture mode' defbug of one of the tries i am working on. If anyone out there has the device files or see's what i am doing wrong, please tell me. It looks from the debug is that it is trying to pull the config, but it is all messed up in the format. the error resport i get is 'failed to download device config'..
thanks,
Jeff
<NEWSESSION Kiwi CatTools 3.3.7 3/12/2009 3:06:29 PM>
<PROTOCOL=Telnet>
<DEVICE TYPE=Cisco.Switch.IOS>
<ACTIVITY TYPE=Device.Backup.Running Config>
<ACTIVITY SCRIPT=C:\Program Files\CatTools3\Scripts\Client.Device.Backup.Running Config.txt>
<USERS NAME FOR DEVICE=SH-DrPardue-OB-MRV910>
<C OK 3:06:29 PM><R-3:06:29 PM>[13][13][10]MRV OptiSwitch 910 version 2_0_11[13][10][13]SH-DrPardue-OB-MRV910 login: <W-3:06:29 PM>#51fib3r[13][10]<R-3:06:29 PM>#51fib3r[13][10]<W-3:06:29 PM>[13]<R-3:06:29 PM>Password: <R-3:06:30 PM>[13][10]<R-3:06:36 PM>Login incorrect[13][10][13][10]SH-DrPardue-OB-MRV910 login:
WFMDRetVal=1 Waiting for: ">"
WFMDRetVal=2 Waiting for: "#"
WFMDBuffer="password: [13][10]login incorrect[13][10][13][10]sh-drpardue-ob-mrv910 login: "
<R-3:07:29 PM>[13][10]Login timed out after 60 seconds.[13][10]<D 3:07:29 PM>
<SCRIPT VALUES>
<HOSTNAME="">
<PROMPT VTY="">
<PROMPT ENABLE="">
<PROMPT CONFIG="">
<NEWSESSION Kiwi CatTools 3.3.7 3/12/2009 3:08:15 PM>
<PROTOCOL=Telnet>
<C OK 3:08:15 PM><R-3:08:15 PM>[13][13][10]MRV OptiSwitch 910 version 2_0_11[13][10][13]SH-DrPardue-OB-MRV910 login: <W-3:08:16 PM>admin[13]<R-3:08:16 PM>admin[13][10]<R-3:08:16 PM>Password: <W-3:08:16 PM>#51fib3r[13]<R-3:08:16 PM>[13][10]<R-3:08:16 PM>Last login: Thu Mar 12 20:02:41 2009 on pts/0[13][10][13][10]<R-3:08:18 PM>ATTENTION: LOGOUT timeout is set to 30 min.[13][13][10]<R-3:08:18 PM>SH-DrPardue-OB-MRV910> <W-3:08:18 PM>[13]<R-3:08:18 PM>[13][10]<R-3:08:18 PM>SH-DrPardue-OB-MRV910> <W-3:08:19 PM>enable<R-3:08:19 PM>enable<W-3:08:19 PM>[13]<R-3:08:19 PM>[13][10]<R-3:08:19 PM>SH-DrPardue-OB-MRV910# <W-3:08:19 PM>term no mon<R-3:08:19 PM>term no mon<W-3:08:19 PM>[13]<R-3:08:19 PM>[13][10]<R-3:08:19 PM>SH-DrPardue-OB-MRV910# <W-3:08:19 PM>term len 0<R-3:08:19 PM>term len 0<W-3:08:19 PM>[13]<R-3:08:19 PM>[13][10]<R-3:08:19 PM>% Ambiguous command $term len 0$.[13][10]SH-DrPardue-OB-MRV910# <W-3:08:19 PM>sh run<R-3:08:19 PM>sh run<W-3:08:20 PM>[13]<R-3:08:20 PM>[13][10]<R-3:08:20 PM>Building configuration...[13][10][13][10]Current configuration:[13][10]! version 2_0_11[13][10]![13][10]hostname SH-DrPardue-OB-MRV910[13][10]![13][10]action-list Cust-5M[13][10] tc-action[13][10] drop-red[13][10] counter-set-number 1 [13][10] rate single-leaky-bucket cir 5m cbs 4K [13][10]![13][10]access-list extended Cust-5M[13][10] rule 10[13][10] action list Cust-5M[13][10]![13][10]port description 1 Customer-Handoff-Dr Pardue [13][10]port description 2 Customer-Handoff-Callis [13][10]port description 9 ***TO Meyers GS G2/35*** [13][10]port description 10 ***NOT IN USE*** [13][10]port state disable 3-8,10[13][10]--More--
<NEWSESSION Kiwi CatTools 3.3.7 3/12/2009 3:09:58 PM>
<PROTOCOL=Telnet>
<C OK 3:09:58 PM><R-3:09:58 PM>[13][13][10]MRV OptiSwitch 910 version 2_0_11[13][10][13]SH-DrPardue-OB-MRV910 login: <W-3:09:58 PM>admin[13]<R-3:09:58 PM>admin[13][10]<R-3:09:59 PM>Password: <W-3:09:59 PM>#51fib3r[13]<R-3:09:59 PM>[13][10]<R-3:09:59 PM>Last login: Thu Mar 12 20:09:25 2009 on pts/0[13][10][13][10]<R-3:10:01 PM>ATTENTION: LOGOUT timeout is set to 30 min.[13][13][10]<R-3:10:01 PM>SH-DrPardue-OB-MRV910> <W-3:10:01 PM>[13]<R-3:10:01 PM>[13][10]<R-3:10:01 PM>SH-DrPardue-OB-MRV910> <W-3:10:01 PM>enable<R-3:10:01 PM>enable<W-3:10:01 PM>[13]<R-3:10:01 PM>[13][10]<R-3:10:02 PM>SH-DrPardue-OB-MRV910# <W-3:10:02 PM>term no mon<R-3:10:02 PM>term no mon<W-3:10:02 PM>[13]<R-3:10:02 PM>[13][10]<R-3:10:02 PM>SH-DrPardue-OB-MRV910# <W-3:10:02 PM>term len 0<R-3:10:02 PM>term len 0<W-3:10:02 PM>[13]<R-3:10:02 PM>[13][10]<R-3:10:02 PM>% Ambiguous command $term len 0$.[13][10]SH-DrPardue-OB-MRV910# <W-3:10:02 PM>show running<R-3:10:02 PM>show running<W-3:10:02 PM>[13]<R-3:10:03 PM>[13][10]<R-3:10:03 PM>Building configuration...[13][10][13][10]Current configuration:[13][10]! version 2_0_11[13][10]![13][10]hostname SH-DrPardue-OB-MRV910[13][10]![13][10]action-list Cust-5M[13][10] tc-action[13][10] drop-red[13][10] counter-set-number 1 [13][10] rate single-leaky-bucket cir 5m cbs 4K [13][10]![13][10]access-list extended Cust-5M[13][10] rule 10[13][10] action list Cust-5M[13][10]![13][10]port description 1 Customer-Handoff-Dr Pardue [13][10]port description 2 Customer-Handoff-Callis [13][10]port description 9 ***TO Meyers GS G2/35*** [13][10]port description 10 ***NOT IN USE*** [13][10]port state disable 3-8,10[13][10]--More--
<NEWSESSION Kiwi CatTools 3.3.7 3/12/2009 3:13:40 PM>
<PROTOCOL=Telnet>
<ACTIVITY TYPE=Device.ConnectivityTest.Login>
<ACTIVITY SCRIPT=C:\Program Files\CatTools3\Scripts\Client.Device.ConnectivityTest.Login.txt>
<PROTOCOL=Telnet>
<SCRIPT VALUES>
<HOSTNAME="">
<PROMPT VTY="">
<PROMPT ENABLE="">
<PROMPT CONFIG="">
<PROTOCOL=Telnet>
<PROTOCOL=Telnet>
<PROTOCOL=Telnet>
<C OK 3:13:40 PM><R-3:13:40 PM>[13][13][10]MRV OptiSwitch 910 version 2_0_11[13][10][13]SH-DrPardue-OB-MRV910 login: <W-3:13:40 PM>admin[13]<R-3:13:40 PM>admin[13][10]<R-3:13:40 PM>Password: <W-3:13:41 PM>#51fib3r[13]<R-3:13:41 PM>[13][10]<R-3:13:41 PM>Last login: Thu Mar 12 20:10:33 2009 on pts/1[13][10][13][10]<R-3:13:43 PM>ATTENTION: LOGOUT timeout is set to 30 min.[13][13][10]<R-3:13:43 PM>SH-DrPardue-OB-MRV910> <W-3:13:43 PM>[13]<R-3:13:43 PM>[13][10]<R-3:13:43 PM>SH-DrPardue-OB-MRV910> <W-3:13:43 PM>[13]<R-3:13:43 PM>[13][10]<R-3:13:43 PM>SH-DrPardue-OB-MRV910> <W-3:13:43 PM>[13]<R-3:13:43 PM>[13][10]<R-3:13:44 PM>SH-DrPardue-OB-MRV910> <W-3:13:44 PM>exit[13]<D 3:13:44 PM>
<SCRIPT VALUES>
<HOSTNAME="SH-DrPardue-OB-MRV910">
<PROMPT VTY="SH-DrPardue-OB-MRV910>">
<PROMPT ENABLE="SH-DrPardue-OB-MRV910#">
<PROMPT CONFIG="">
<SCRIPT VALUES>
<PROMPT CONFIG="">
