Community
Command Central
MVP Program
Monthly Mission
Blogs
Groups
Events
Media Vault
SolarWinds Academy
Products
Goal Oriented AI
Observability
Application Management
IT Security
IT Service Management
System Management
Database Management
Content Exchange
SolarWinds Platform
Server & Application Monitor
Database Performance Analyzer
Server Configuration Monitor
Network Performance Monitor
Network Configuration Manager
SQL Sentry
Web Help Desk
Free Tools & Trials
Store
Home
Products
Network Performance Monitor Startup Error
srhodes
* Upgraded from version 6.4 to version 7.1. Ran unload of 6.4, rebooted, then loaded 7.1
* No problem in the upgrade.
* After an hour or so, when trying to access the web page I receive the following error:
Cannot start SolarWinds Orion NPM Web Engine (OrionNPMWeb.Application).
Error Number -2147024882
006~ASP 0177~Server.CreateObject Failed~Ran out of memory
You may need to rerun the SolarWinds Configuration Wizard.
Visit
www.solarwinds.net/.../Security
for more detailed information.
* From the server console, within Task Manager, the DLLHOST.EXE process is utilizing the most memory. Username= IISUSER_SOLARWINDS MemUsage = 1,614,324K. The server has 2GB of memory.
* When I terminate DLLHOST.EXE, I am able to access the web page. Then again, after an hour or so, the page is unavailable. There may be a memory leak.
Any suggestions?
Sandy Rhodes
Find more posts tagged with
Accepted answers
All comments
cshiver
No suggestions, but can tell you that I am having the exact same problem.
- Chris Shiver
iunderwo
I started my SW deployment w/ 7.0 but here's something you might want to try.
* Run install per upgrade requirements.
* Remove C:\Inetpub\SolarWinds
* Reinstall
DLLHost can act really strangely from time to time.
// Ian Underwood - Service Management
// Level 3 Communications
cshiver
I actually did find a way to fix this issue...well, Solarwinds techsupport did.
They said that the error was related to Windows 2000 SP3 which I happen to be running (though I thought I'd already upgraded to SP 4).
I upgraded to SP 4 and I've been good since.
- Chris Shiver
Quick Links
All Categories
Recent Posts
Activity
Unanswered
Groups
Help
Best Of
