Community
Command Central
MVP Program
Monthly Mission
Blogs
Groups
Events
Media Vault
SolarWinds Academy
Products
Observability
Application Management
IT Security
IT Service Management
System Management
Database Management
Goal Oriented AI
Content Exchange
SolarWinds Platform
Server & Application Monitor
Database Performance Analyzer
Server Configuration Monitor
Network Performance Monitor
Network Configuration Manager
SQL Sentry
Web Help Desk
Free Tools & Trials
Store
Home
Products
Engineer's Toolset
Database Size Warning
bro142
After tranfering all my data from my PC to a central server, I was advised to copy over certain files accross also to enable my server to have the 3 months history from my PC. this included my SWNetPerfMon.cfg file of 2 gigabit
now I'm getting a database size warning informing me to stop polling and run database maintenance. I cannot open the SWNetPerfMon file in an attempt to delete folders. does anyone have any ideas??
G
GB
Find more posts tagged with
Accepted answers
All comments
Bryan
This is the biggest limitation to the Toolsets. To perform the maintenance, make sure that NetPerfMon is shutdown. Look in the solarwinds directory and there is an exe file call Database-Maint.exe kick this file off and fun the utility. This will shrink the access database size greatly and allow for continued monitoring. Depending on the amount of objects your monitoring, you'll need to get used to doing this on a regular basis.
Lockheed Martin
Atlas V Launch Operations
Network Engineer
ddaryl
I just repaired my corrupt database this morning
If the database is corrupted open the database (SWNetPerfMon.cfg) with MS Access if you can and allow it to repair. This can take 10 minutes or more. I did this because the solarwinds database exe woudln't work unit after I repaired with MS Access
Then run the Solar Winds database repair .exe located somewhere in the Program files/solarwinds folder. (
Then go ahead an run performance monitor
LynxRC
ddaryl,
Thanks for the tip, I've just finished repairing with MS Access as my SWNetPerfMon.cfg file had hit 2 Gig and corrupted. After following your advice it is now back with all data at a size of 55 Meg
Cheers
LynxRC
fleic0ma
<quote>.....you'll need to get used to doing this on a regular basis.
So I am not having problems when I need to run the 'repair and compact database' tool weekly? I was ready to ping the SolarWinds support group about this, but it sounds like it is 'normal' behavior.
greg
fleic0ma,
As Bryan says, it is the biggest limitation of the TOOLSET. Have you seen Orion? Orion stores data on SQL server, which does not have the 2GB limit, and is developed and tuned for monitoring larger networks than the toolset.
www.solarwinds.net/.../index.htm
Greg
Bryan
The two main differences between Toolsets and Orion are the database limitation and the web capability. Solarwinds has integrated the syslog server in Toolsets into SQL, why not the NPM? I own both products and from personal experience, the reason that I purchased Orion was for the web capability. I don't see why Solarwinds wouldn't want to add the SQL feature to toolsets, I don't think it would compete with Orion.
Lockheed Martin
Network Engineer
Quick Links
All Categories
Recent Posts
Activity
Unanswered
Groups
Help
Best Of
