Community
Command Central
MVP Program
Monthly Mission
Blogs
Groups
Events
Media Vault
SolarWinds Academy
Products
Observability
Application Management
IT Security
IT Service Management
System Management
Database Management
Content Exchange
SolarWinds Platform
Server & Application Monitor
Database Performance Analyzer
Server Configuration Monitor
Network Performance Monitor
Network Configuration Manager
SQL Sentry
Web Help Desk
Free Tools & Trials
Store
Home
Products
node names by ports
Gennady
is there a simple way to see which pc/server is connected to specific switch port?
not necessarily node name - MAC or IP will be enough.
thx in advance,
Gennady
Find more posts tagged with
Accepted answers
All comments
Network_Guru
You can use the switch port mapper if you have Solarwinds Engineering Edition.
Otherwise you would have to do this manually with the command line software in your switch/router.
In Cisco it is - show ip arp, and show cam dynamic.
-=Cheers=-
NG
FrederickRojas
Actually, I've been hopeing that they incorporate the Switch port mapper functionality into Orion. Especially on the detail view of a switch. Wouldn't it br great to drill in to a switch on the web browser and see whats attached to each port?
Frederick Rojas
Senior Network Engineer, LCI
Network_Guru
This information should actually come from the SNMP port description MIB.
I've been asking for this to be supported for the past year now on Catalyst switches running CatOS. Then you would just have to label your switch ports in one place.
The MIBs are there, they are just not polling them with Orion.
-=Cheers=-
NG
Quick Links
All Categories
Recent Posts
Activity
Unanswered
Groups
Help
Best Of
