Community
Command Central
MVP Program
Monthly Mission
Blogs
Groups
Events
Media Vault
SolarWinds Academy
Products
Observability
Application Management
IT Security
IT Service Management
System Management
Database Management
Content Exchange
SolarWinds Platform
Server & Application Monitor
Database Performance Analyzer
Server Configuration Monitor
Network Performance Monitor
Network Configuration Manager
SQL Sentry
Web Help Desk
Free Tools & Trials
Store
Home
Products
Application Monitor Problem
ringo73
Application Monitor seems to show certain processes stop yet when I log in the servers both the services and the processes are running. Has anyone else run into this error or knows how to correct it. app monitor is 7.8.3 and the server is W2K3 SP1.
Find more posts tagged with
Accepted answers
All comments
CCrew
Depends on what you're monitoring. Case in point being Apache on a Linux box, it will spawn multiple httpd entries and if you do not turn off "Log Application Stop/Start Events" for httpd you will be flooded with alerts as it spawns and shuts down new instances. The master service istelf will still flag/alert if it fails in that scenario. Some more detail as to what you're having problems with may be helpful here so that people can jump in and tell you what's worked for them.
Regards,
Roger
ringo73
problem is the ntfrs.exe service at certain point during the day the solarwinds will show the application as stopped, log into the server and it is running, the fix that i had was to delete the monitored application and readd to the server
Quick Links
All Categories
Recent Posts
Activity
Unanswered
Groups
Help
Best Of
