Community
Command Central
MVP Program
Monthly Mission
Blogs
Groups
Events
Media Vault
SolarWinds Academy
Products
Goal Oriented AI
Observability
Application Management
IT Security
IT Service Management
System Management
Database Management
Content Exchange
SolarWinds Platform
Server & Application Monitor
Database Performance Analyzer
Server Configuration Monitor
Network Performance Monitor
Network Configuration Manager
SQL Sentry
Web Help Desk
Free Tools & Trials
Store
Home
Products
Node List - Custom Grouping and Filtering
SamuelB
I am trying to filter nodes based on a custom property. I am able to successfully do this as long as I have populated the custom property (SortGroup). However, I want to create a separate node list that contains all the nodes that do not the custom property populated (i.e. if they are newly added nodes or the custom property is deliberately left blank). When I try to filter on SortGroup='' no nodes appear in the list. Is there a different way to query for a custom property field containing a null value?
SamuelB
Find more posts tagged with
Accepted answers
All comments
RyanJett
SamuelB,
Try this filter:
SortGroup IS NULL
If that does not work, try creating a Report in Report Writer to show the same list of Nodes.
Ryan Jett
SolarWinds.Net
918-307-8100
SamuelB
Ryan,
That filter worked fine. I had tried everything except for the word "IS". Thank you for your help.
SamuelB
Quick Links
All Categories
Recent Posts
Activity
Unanswered
Groups
Help
Best Of
