Community
Command Central
MVP Program
Monthly Mission
Blogs
Groups
Events
Media Vault
Products
Observability
Application Management
IT Security
IT Service Management
System Management
Database Management
Content Exchange
SolarWinds Platform
Server & Application Monitor
Database Performance Analyzer
Server Configuration Monitor
Network Performance Monitor
Network Configuration Manager
SQL Sentry
Web Help Desk
Free Tools & Trials
Store
Home
Products
Swapping devices
skaczkowski
All,
Been playing around with Cirrus a bit and so far we like what we see, but I'm wondering about one thing. Doing some testing I've put a 3500 (48 port) on the wire, discovered it, baselined it,etc. I then went ahead and swapped in a 2950 (24 port) in its place with the same IP address and ran an inventory. It went ahead and rediscovered the switch, but it still thinks it's a 3500 and when I run a report or a config compare it just says there are 5845349345 or so changes. It has NO idea that it's actually a completely different platform.
So, my question is there some other means for Cirrus to deal with this or is it a totally manual process and not soo smart like CiscoWorks?
What are you guys doing in order to deal with things like this?
Thanks!
Find more posts tagged with
Accepted answers
All comments
FormerMember
I just replaced a router that was already in Cirrus, and it did eventually rediscover it as a different Router model than was previously in place.
I haven't figured out the discovery timing yet, or if it can be triggered manually, but it will eventually happen.
I've been playing with "snmp-server location" settings as a way to group my devices. Even if I force a config download or a device inventory, the location setting doesn't kick in. It is seeming like it takes a day or so depending on the rediscovery schedule (which I don't know how to modify yet)
Over all, I like Cirrus, but I still think there are some things that should have been addressed before V. 3
skaczkowski
Yup, we found out the same thing. I think it figures it out during the next inventory, although I thought I tested it and it didn't work... Maybe it takes a couple inventories or something..
Either way it works which LIGHT YEARS ahead of braindead Ciscoworks...
-SK
Quick Links
All Categories
Recent Posts
Activity
Unanswered
Groups
Help
Best Of
