Community
Command Central
MVP Program
Monthly Mission
Blogs
Groups
Events
Media Vault
SolarWinds Academy
Products
Observability
Application Management
IT Security
IT Service Management
System Management
Database Management
Content Exchange
SolarWinds Platform
Server & Application Monitor
Database Performance Analyzer
Server Configuration Monitor
Network Performance Monitor
Network Configuration Manager
SQL Sentry
Web Help Desk
Free Tools & Trials
Store
Home
Products
LAN Report
cmccarter
First off, I must admit I'm not sql savy. I'm trying to generate a report showing my historic LAN traffic for the past 6-12 months. I've really no idea where to begin. Can someone point me in the right starting direction.
Find more posts tagged with
Accepted answers
All comments
Network_Guru
The built in Report Writer is quite user friendly.
As far a "LAN" report, that is somewhat ambiguous, so it's hard to give you any specifics.
As a start you could create a report based on all the uplinks between your LAN switches.
To make it easier to specify the interfaces to be used in the report, you will want to open up the custom property editor (CPE) & select "Interfaces".
Create a custom property for specifiying the interfaces you want to use in this report(call it "reports" or something similar).
Now enter a description in this property that will be used to select the interfaces you want to report on (call it "LAN report").
Now when you go into the report writer you can create a filter based on this description field. Basically it will be something like "Show me any interfaces with the custom interface property Reports which are equal to LAN report.
Check the on-line dox, as I believe they have a very good rundown on how to do this.
www2.solarwinds.net/.../default.htm
-=Cheers=-
NG
Quick Links
All Categories
Recent Posts
Activity
Unanswered
Groups
Help
Best Of
