I keep getting this error when trying to run CatTools against some devices.
Client script error: Automation error<LF>A dynamic link library (DLL) initialization routine failed.
It does it on say about the first 10 devices, it throws up a window saying can't set allocations and after hitting OK about ten times the activity runs fine. I'm running CatTools on Vista but if I run it in XP it runs fine and I never get this error. I also turned off the UAC and told Vista to run CatTools in XP Compatibility Mode. What do I need to change to get this to run correctly. I tried installing as a service and I can run one activity but any activity I run afterwards just hangs and hangs and won't allow me to run another activity unless I reboot the box.
