Community
Command Central
MVP Program
Monthly Mission
Blogs
Groups
Events
Media Vault
SolarWinds Academy
Products
Observability
Application Management
IT Security
IT Service Management
System Management
Database Management
Content Exchange
SolarWinds Platform
Server & Application Monitor
Database Performance Analyzer
Server Configuration Monitor
Network Performance Monitor
Network Configuration Manager
SQL Sentry
Web Help Desk
Free Tools & Trials
Store
Home
Products
Maps created with Visio not displayed corrctly
Griptypethin
After I upgraded to version 8.01 from 7.81, the maps which have been created from Microsoft Visio, now appear as a grey circle. Can anyone provide any help with this?
Find more posts tagged with
Accepted answers
All comments
rsfox
Go to the folder where you had the gif files in 7.x and copy them to the maps folder in 8.0 manually.
Rich Fox
Griptypethin
I already copies them to the new folder. The problem is when i try to open one, instead of a network map i get a large grey circle ???
Szygenda
Could you please provide us with more details about the version of Visio you are using, the image format and the way you imported the images into Map Maker
Mark Szygenda
SolarWinds
Griptypethin
I created the maps in Microsoft Visio 2003, file format .vsd. They are then Copied to the clipboard and paste special into Map Maker. I'm sure this is quite a widespread practice and am suprised there haven't been more instances reported.
BryanBecker
Try saying the visio as a .jpg. Copy that to the maps directory and then select it to be your background. Once saved in MapMaker it will convert it to .gif.
BB
jtimes
I have found less issues with the graphics if I save them as a .gif (stick to the default format) directly from Visio
John J. Times
Quick Links
All Categories
Recent Posts
Activity
Unanswered
Groups
Help
Best Of
