Community
Command Central
MVP Program
Monthly Mission
Blogs
Groups
Events
Media Vault
SolarWinds Academy
Products
Observability
Application Management
IT Security
IT Service Management
System Management
Database Management
Content Exchange
SolarWinds Platform
Server & Application Monitor
Database Performance Analyzer
Server Configuration Monitor
Network Performance Monitor
Network Configuration Manager
SQL Sentry
Web Help Desk
Free Tools & Trials
Store
Home
Products
Problem Logging onto Cisco 2600 Router
jonchill
I've added one of our routers to Cirrus and it logs in fine but does not seem to login to enable, when I try and run a command I get the following
show IP Traffic
Pilgrim-Lincoln>show IP Traffic
Which shows it is connected but not logged into enable, our console password is the same as our enable password and it's all configured correctly in the node details, anyone know why it's not logging into enable.
Node Details
Node ID {635B8960-ED18-4694-BBF7-941292EEE7CE}
Node Name Pilgrim-Lincoln ${SysName}
Node Group
IP Address 10.42.1.5
SNMP Community String public ${GlobalCommunity}
Comments
Discovered Properties
Reverse DNS
Response Time 1 ms
Response Error OK
Device Status Up
SNMP Level SNMP V2
System Name Pilgrim-Lincoln
System Description Cisco Internetwork Operating System Software
IOS (tm) C2600 Software (C2600-I-M), Version 12.2(24), RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2004 by cisco Systems, Inc.
Compiled Wed 28-Apr-04 15:30 by kellmill
System Contact
System Location
System OID 1.3.6.1.4.1.9.1.186
Vendor Cisco
Machine Type Cisco 2611
Last Boot 06:01 AM
OS Image C2600-I-M
OS Version 12.2(24), RELEASE SOFTWARE (fc1)
Supported Config Types Running, Startup
Next Rediscovery 09:52 AM
Next Poll 09:07 AM
Login Information
User Name
Password ********
Enable Level enable 15
Enable Password ********
Communication
Device Command Template Auto Determine
Command Exec Protocol TELNET ${GlobalExecProtocol}
Config Transfer Protocols TELNET ${GlobalTransferProtocol}
Last Login Result Login OK
Browse via HTTPs No
Last Inventory 08:55 AM
Jon
IT Infrastructure Manager
Pilgrim Hospital
UK
Find more posts tagged with
Accepted answers
All comments
greg
Jon,
When logging into this device, do you normally type 'enable' or 'enable 15'? The way the node is setup, it will actually send 'enable 15' for the privileged access attempt. Try setting the enable level in the device properties to the string that you normally type for privileged access.
If that doesn't work, give our support team a call they would be happy to help.
918-307-8100
Greg
jonchill
I've changed it to enable still doesn't work.
I added a different router and it worked fine the only difference being is that the router that does not work only requires a password and no login name whereas the one that works has a login name and password.
Couls this be causing the problem?
Jon
Pilgrim Hospital
UK
greg
Jon,
We should be able to handle that situation. Can you get me a trace of the login validation? If so, send it to Josh@Solarwinds.net
Greg
Quick Links
All Categories
Recent Posts
Activity
Unanswered
Groups
Help
Best Of
