Hi Geeks,
The timezone in x-axis is incorrect.
When mouse-over the bar, the time is correct indeed
Would you tell me how to fix it?
Below is my screenshot
If you go to the CMC shell on the LEM, go to APPLIANCE, enter DATECONFIG and hit enter 4 times, what timezone is the LEM set to?
You can use the TZCONFIG command under the APPLIANCE menu to change the timezone.
