Community
Command Central
MVP Program
Monthly Mission
Blogs
Groups
Events
Media Vault
SolarWinds Academy
Products
Goal Oriented AI
Observability
Application Management
IT Security
IT Service Management
System Management
Database Management
Content Exchange
SolarWinds Platform
Server & Application Monitor
Database Performance Analyzer
Server Configuration Monitor
Network Performance Monitor
Network Configuration Manager
SQL Sentry
Web Help Desk
Free Tools & Trials
Store
Home
Products
Engineer's Toolset
Ports on Macintosh PCs
boe
I was using Port Scanner 8.2 to try and find out if anyone was using P2P software - what I noticed was that none of our Macintosh systems (all OSX) displayed any port information. I set it to scan one at a verified IP address and it would vary from saying (just port 20) was in use or that port had an error.
What I'd like to do is run a scan to find out how much each bandwidth each system is using. One of the key ports of interest is AFP. Since I can't seem to scan the MACs using port scanner (for ANY ports) I was wondering if there is setting I need to change.
Also I would like to know what is the correct component to use as I am new to the SolarWinds Engineers product.
Thank you
Find more posts tagged with
Accepted answers
All comments
Bryan
The best tool for monitoring traffic across a network is Netflow Analyzer. If your running cisco routers, configure up a flow and send it to your network monitor. Netflow Analyzer is free to try and tracks all IP communication, both source, destination, protocol, size and amount of traffic.
Lockheed Martin
Atlas V Launch Operations
Network Engineer
boe
Thanks - I'm using a sonicwall firewall and unmanaged switches.
Quick Links
All Categories
Recent Posts
Activity
Unanswered
Groups
Help
Best Of
