Community
Command Central
MVP Program
Monthly Mission
Blogs
Groups
Events
Media Vault
SolarWinds Academy
Products
Observability
Application Management
IT Security
IT Service Management
System Management
Database Management
Goal Oriented AI
Content Exchange
SolarWinds Platform
Server & Application Monitor
Database Performance Analyzer
Server Configuration Monitor
Network Performance Monitor
Network Configuration Manager
SQL Sentry
Web Help Desk
Free Tools & Trials
Store
Home
Products
NT pass-through security not working
webberb
I'm running Orion V7 on a Windows 2000 box and I want to authenticate back to my AD domain. I followed the steps in the manual to enable NT pass-through security (I unchecked anonymous access and checked integrated windows security), and added my username in the form domain\username, but it still doesn't work.
Any gotchas I need to know about to make this work?
Find more posts tagged with
Accepted answers
All comments
Network_Guru
Have you tried stopping and re-starting IIS ?
-=Cheers=-
NG
webberb
Never mind.... got it working.
BryanBecker
On a different topic...has anyone notice that pass-thru will not work unless the account is either a domain admin or local admin on the server?
I added a user domain\username and he gets a windows pop-up to put in his credentials. He does so and the server won't let him in. If I put his account as a local admin then he works fine, any other group he still gets the pop up and can't get in.
Anyone seen this a got around it without having to make these people admins??
snowjay
Bryan,
Sounds like permissions are not set right on the SolarWinds folder under Inetpub.
Jason
BryanBecker
What permissions need to be set under that folder?
The group Everyone has Read, Read & Execute and List folder contents selected.
Network_Guru
Try re-running the Web site part of the Installation wizard again.
Just cancel the install wizard after it has installed the web site.
It sets up the permissions correctly for you.
-=Cheers=-
NG
alteon180e
I was wondering if anyone has tried auto login for a group of users. If i have a group called "domain\network admins" with a user called "bob" in it. Can i add the group to account manager, or is it only userid passthrough. I am 99% sure that i would have to add "domain\bob" for him to get his (or his group's) customized views. Just wondering if anyone has done this successfully, or im just dead wrong
Network_Guru
Check this post:
www2.solarwinds.net/.../topic.asp
I've played with using AD groups, but it only seems to work for the domain\everyone group.
I'd sure like to be able to use the built-in AD groups, rather than adding individual accounts.
That way I could give our helpdesk(~20 users) limited access to the webpage and not have to bother when users come & go.
-=Cheers=-
NG
Quick Links
All Categories
Recent Posts
Activity
Unanswered
Groups
Help
Best Of
