I tried to get the Outlet Configuration from our PDU's.
Login is successful and menu navigation seems to be ok, but output is not as expected:
1
------- Device Manager --------------------------------------------------------
1- Bank Management
2- Outlet Management
3- Power Supply Status
<ESC>- Back, <ENTER>- Refresh, <CTRL-L>- Event Log
2
------- Outlet Management -----------------------------------------------------
1- Outlet Control/Configuration
2- Outlet Restriction
Debug is:
<NEWSESSION Kiwi CatTools 3.4.0 21.10.2009 14:11:05>
<PROTOCOL=Telnet>
<DEVICE TYPE=APC.AOS>
<ACTIVITY TYPE=Device.CLI.Send commands>
<ACTIVITY SCRIPT=C:\Program Files\CatTools3\Scripts\Client.Device.CLI.Send commands.txt>
<USERS NAME FOR DEVICE=PW50MGMT01>
<C OK 14:11:05><R-14:11:05>[10][13]User Name : <W-14:11:05>apc[13]<R-14:11:05>apc[10][13]Password : <W-14:11:05>apc[13]<R-14:11:05>***<R-14:11:05>[10][10][10][13]American Power Conversion Network Management Card AOS v3.7.0[13][10](c) Copyright 2008 All Rights Reserved Rack PDU APP v3.7.0[13][10]-------------------------------------------------------------------------------[13][10]Name : PW50MGMT01 Date : 10/21/2009[13][10]Contact : XXXXXX Time : 13:11:05[10][13]Location : XXXXXXXXXXX 14005556 User : Administrator[10][13]Up Time : 253 Days 1 Hour 46 Minutes Stat : P+ N+ A+[13][10][13][10]Switched Rack PDU: Communication Established[10][10][13]<R-14:11:05>------- Control Console -------------------------------------------------------[13][10][13][10] 1- Device Manager[13][10] 2- Network[13][10] 3- System[13][10] 4- Logout[13][10][13][10] <ESC>- Main Menu, <ENTER>- Refresh, <CTRL-L>- Event Log[13][10]> <W-14:11:07>[13]<R-14:11:07>[10][10][13]------- Control Console -------------------------------------------------------[13][10][13][10] 1- Device Manager[13][10] 2- Network[13][10] 3- System[13][10] 4- Logout[13][10][13][10] <ESC>- Main Menu, <ENTER>- Refresh, <CTRL-L>- Event Log[13][10]> <W-14:11:11>1<W-14:11:11>[13]<R-14:11:11>1[10][10][13]<R-14:11:11>------- Device Manager --------------------------------------------------------[13][10][13][10] 1- Bank Management[13][10] 2- Outlet Management[13][10] 3- Power Supply Status[13][10][13][10] <ESC>- Back, <ENTER>- Refresh, <CTRL-L>- Event Log[13][10]> <W-14:11:14>2<W-14:11:14>[13]<R-14:11:14>2<R-14:11:14>[10][10][13]------- Outlet Management -----------------------------------------------------[13][10][13][10] 1- Outlet Control/Configuration[13][10] 2- Outlet Restriction[13][10][13][10] <ESC>- Back, <ENTER>- Refresh, <CTRL-L>- Event Log[13][10]> <W-14:11:17>1<R-14:11:17>1<W-14:11:17>[13]<R-14:11:17>[10][10][13]<R-14:11:17>------- Outlet Control/Configuration ------------------------------------------[13][10][13][10]<R-14:11:17> 1- ASA50 ON[13][10] 2- Outlet 2 ON[13][10] 3- Outlet 3 ON[13][10]<R-14:11:17> 4- Outlet 4 ON[13][10]<R-14:11:17> 5- Outlet 5 ON[13][10] 6- FW0WAF01 ON[13][10] 7- Outlet 7 ON[13][10] 8- Outlet 8 ON[13][10] 9- Outlet 9 ON[13][10] 10- Outlet 10 ON[13][10] 11- Outlet 11 ON[13][10] 12- Outlet 12 ON[13][10] 13- Outlet 13 ON[13][10] 14- Outlet 14 ON[13][10] 15- Outlet 15 ON[13][10] 16- Outlet 16 ON[13][10] 17- Outlet 17 ON[13][10] 18- Outlet 18 ON[13][10] 19- Outlet 19 ON[13][10]<R-14:11:17> 20- Outlet 20 ON[13][10]<R-14:11:17> 21- Outlet 21 ON[13][10]<R-14:11:17> 22- Outlet 22 ON[13][10]<R-14:11:17>[13] Press <ENTER> to continue...<W-14:11:17>[13]<R-14:11:18>[13] [13] 23- Outlet 23 ON[13][10] 24- Outlet 24 ON[13][10] 25- Master Control/Configuration[13][10][13][10] <ESC>- Back, <ENTER>- Refresh, <CTRL-L>- Event Log[13][10]>
Commands used are:
%ctUM: EchoOff
%ctUM:PauseTime 02
1
%ctUM:PauseTime 02
2
%ctUM: EchoOn
%ctUM:PauseTime 02
1
Info Log:
2009-10-21 14:11:04 3-Info 0 Kiwi CatTools Service Performing activity - Run Now
2009-10-21 14:11:04 3-Info 0 Kiwi CatTools Service Loading activity: TEST_APC_Ports. Schd: 26
2009-10-21 14:11:04 4-Debug 0 Kiwi CatTools Service Marshaller - Running script. Device: PW50MGMT01
2009-10-21 14:11:05 4-Debug 1 PW50MGMT01 Connected to 10.252.11.1
2009-10-21 14:11:05 4-Debug 1 PW50MGMT01 Login APC AOS: PW50MGMT01
2009-10-21 14:11:05 4-Debug 1 PW50MGMT01 Beginning Login AAA
2009-10-21 14:11:05 4-Debug 1 PW50MGMT01 Sending login AAA username
2009-10-21 14:11:05 4-Debug 1 PW50MGMT01 Sending login AAA password
2009-10-21 14:11:07 4-Debug 1 PW50MGMT01 DeviceHostnameID: N/A
2009-10-21 14:11:07 4-Debug 1 PW50MGMT01 Login to PW50MGMT01 was successful
2009-10-21 14:11:08 4-Debug 1 PW50MGMT01 Device at ------- Control Console ------- menu
2009-10-21 14:11:08 4-Debug 1 PW50MGMT01 %ctUM: EchoOff processed successfully
2009-10-21 14:11:09 3-Info 1 PW50MGMT01 Pausing for 2 seconds - %ctUM:PauseTime.
2009-10-21 14:11:11 4-Debug 1 PW50MGMT01 %ctUM:PauseTime 02 processed successfully
2009-10-21 14:11:11 4-Debug 1 PW50MGMT01 Waiting for a response to: 1
2009-10-21 14:11:12 4-Debug 1 PW50MGMT01 Device at ------- Device Manager ------- menu
2009-10-21 14:11:12 3-Info 1 PW50MGMT01 Pausing for 2 seconds - %ctUM:PauseTime.
2009-10-21 14:11:14 4-Debug 1 PW50MGMT01 %ctUM:PauseTime 02 processed successfully
2009-10-21 14:11:14 4-Debug 1 PW50MGMT01 Waiting for a response to: 2
2009-10-21 14:11:15 4-Debug 1 PW50MGMT01 Device at ------- Outlet Management ------- menu
2009-10-21 14:11:15 4-Debug 1 PW50MGMT01 %ctUM: EchoOn processed successfully
2009-10-21 14:11:15 3-Info 1 PW50MGMT01 Pausing for 2 seconds - %ctUM:PauseTime.
2009-10-21 14:11:17 4-Debug 1 PW50MGMT01 %ctUM:PauseTime 02 processed successfully
2009-10-21 14:11:17 4-Debug 1 PW50MGMT01 Waiting for an echo of 1 command
2009-10-21 14:11:17 4-Debug 1 PW50MGMT01 Waiting for a response to: 1
2009-10-21 14:11:17 4-Debug 1 PW50MGMT01 Stepping past Press <ENTER> to continue...
2009-10-21 14:11:19 1-Error 1 PW50MGMT01 Client script error: Invalid procedure call or argument: 'InStr' on line: 671
2009-10-21 14:11:19 3-Info 0 Kiwi CatTools Service All threads have finished. Now processing results...
2009-10-21 14:11:19 4-Debug 0 Kiwi CatTools Service No report data found. Not sending report via e-mail.
2009-10-21 14:11:20 4-Debug 0 Kiwi CatTools Service Error notification e-mail was not sent. (Disabled when not in 'Timer' mode)
2009-10-21 14:11:20 3-Info 0 Kiwi CatTools Service Run Now activity has completed
Any Suggestions?
